basic problem with Rf modelling
I am just learning to use comsol..
so I was trying to run simulation for simple dielctric..
the error I get is
" feature : stationary solver 1(sol 1/s1)
error: empty parameter list. "
I was following the circulator model already in comsol for reference..
where there is nothing defined in parameter ..no frequence but still I defined taking care of the error.
still nothing.
I am using comsol 4.2.
1 Reply Last Post 6 sept. 2011, 02:07 UTC−4
Posted: 1 decade ago 6 sept. 2011, 02:07 UTC−4
I suspect you have forgotten to define the frequency range in the solver node, check the doc or an example from the model lirary
Hi I suspect you have forgotten to define the frequency range in the solver node, check the doc or an example from the model lirary -- Good luck Ivar
