Combining solver solutions
I am trying to plot a 1d graph but with solution from 2 different solvers, since I have different boundary conditions.
I am only able to select one solver at a time.
Any help is greatly appreciated.
Thank you.
Shriram
1 Reply Last Post 2 sept. 2011, 15:26 UTC−4
Posted: 1 decade ago 2 sept. 2011, 15:26 UTC−4
the only way is to map the dat over with a coupling variable. You must note that when you write "V" or any other dependent variable name in a COMSOL field, it means in fact V(x,y,z) for any point (x,y,z) corresponding to the selected domain (respectively boundary or edge). So when you do the mapping you must ensure that you can use one selected domain/boundary and get the required nodal inforamtion to resolve corretly the variables
Hi the only way is to map the dat over with a coupling variable. You must note that when you write "V" or any other dependent variable name in a COMSOL field, it means in fact V(x,y,z) for any point (x,y,z) corresponding to the selected domain (respectively boundary or edge). So when you do the mapping you must ensure that you can use one selected domain/boundary and get the required nodal inforamtion to resolve corretly the variables -- Good luck Ivar
