External I vs U in parallel for electrical circuits?
I would like to know why the DAE is inconsistent when I put 2 "External I vs U" branches in parallel in the electrical circuits node? Can't we apply the same circuit voltage to 2 different parts in a 2D model? This way, they don't necessarily share the same current, but the voltage is forced to be the same.
ML
1 Reply Last Post 11 juil. 2011, 01:58 UTC−4
Posted: 1 decade ago 11 juil. 2011, 01:58 UTC−4
Hi Mathieu!
You can use a small serial resistor (1mOhm works for me) for each IvsU, and it will run...
Ralf
Hi Mathieu! You can use a small serial resistor (1mOhm works for me) for each IvsU, and it will run... Ralf
