COMSOL MATLAB link Optimization
Hi There
I'm running a optimization routine linking Comsol simulation and MATLAB uisng optimization function fmincon to fit some of the parameters in a Comsol model which solves some heat and mass transfer euqations for a 2D geometry. The porblem is that the optimization fails in MATLAB and I get the the convergence error for Comsol apparently hitting singularity , while I can converge the case with the same parameters in Comsol also I can run the model inside MATALB as well and get correct results. But when the model function evaluation is done inside fmincon it seems that the Comsol model simulation diverges at a start of the simulation. I played with initial guess and tightening the parameters range or fixing their values but problem persists. Any suggstion? Is there a difference between Comsol solver and MATLAB version? It is a bit puzzling.
Thanks, Al
0 Replies Last Post 5 août 2018, 17:00 UTC−4
Hello alnjy
