convert point into 3D
Posted 7 juin 2011, 12:44 UTC−4 0 Replies
So, I have a list of points (consist of x, y, z coordinates), I first convert all points into solid, and export as .mphbin file, which is later imported as a geometry file, together with other geometry files (in .stl format).
Sometimes I got this error 'Geom3 object expected', I assume it means the odd .mphbin file is not a 3D file, therein not compatible with other .stl files?
Any two cents that I can turn all points into a 3D geometry file?
Many thanks!!
Liwah
Hello LiWah Wong
