LARGE DEFORMATION ALE (moving mesh elements)
I everyone,
I'm solving a 2D contact mechanic problem in the large deformation range. Specifically I have two bodies where the first of the "enters" in the second with a prescribed displacement. The study is parametric so I solve the problem for an increasing value of the initial prescribed dislacement.
Since the second body is 1000 times softer than the first one, I have problems of convergence when the mesh deforms too much. I'm am trying to use ALE but it seems that I'm not able to set the boudary conditions. I have imposed the same prescribed dispacement for the mesh that belongs to the soft body, but I don't get suitable results.
Here I attached the file of the model. Is everything ok? Thanks
Giulio
6 Replies Last Post 9 mai 2012, 09:01 UTC−4
Posted: 1 decade ago 10 avr. 2011, 13:22 UTC−4
I haven't looked at your file yet, but did you define the Contact pair between the right boundaries. By the looks of it the contact isn't defined properly and the bodies are penetrating into each other, hence causing the mesh to deform too much
Posted: 1 decade ago 10 avr. 2011, 17:56 UTC−4
Normally you apply a displacement or a force on one of the solid bodies, and prescribe the displacements of the ALE to follow the u,v of the deformed solids.
You are imposing a displacement on part of the ALE, on top of the contact. And do not forget that the symmetry condition in the solids must also have an equivalent in the ALE (there is no symmetry, you must block the x motion in the symmetry plane in your case
Check out a few of the examples of large deformations and contacts in the model library. Then I'm sure you will get the BC better defined
By the way, why not drop the ALE to start with and look at the deformation with a scale of "1". I do not really see why you need it, at least until you get your contact case running. Another hint use small steps such as a range(0,0.1,10)
Hi Normally you apply a displacement or a force on one of the solid bodies, and prescribe the displacements of the ALE to follow the u,v of the deformed solids. You are imposing a displacement on part of the ALE, on top of the contact. And do not forget that the symmetry condition in the solids must also have an equivalent in the ALE (there is no symmetry, you must block the x motion in the symmetry plane in your case Check out a few of the examples of large deformations and contacts in the model library. Then I'm sure you will get the BC better defined By the way, why not drop the ALE to start with and look at the deformation with a scale of "1". I do not really see why you need it, at least until you get your contact case running. Another hint use small steps such as a range(0,0.1,10) -- Good luck Ivar
Posted: 1 decade ago 12 avr. 2011, 05:49 UTC−4
Thank You Ivar,
do you know if, in order to find it´s better to use a small range step?
Did COMSOL use, to find out the solution at steo i, the solution at the step i-1 ?
Thank You Ivar, do you know if, in order to find it´s better to use a small range step? Did COMSOL use, to find out the solution at steo i, the solution at the step i-1 ?
Posted: 1 decade ago 12 avr. 2011, 09:08 UTC−4
its always better to use "small" steps to allow the solver to follow its optimum, but not smaller than required, that means that sometimes 1 step is enough ;)
Hi its always better to use "small" steps to allow the solver to follow its optimum, but not smaller than required, that means that sometimes 1 step is enough ;) -- Good luck Ivar
Posted: 1 decade ago 12 oct. 2011, 13:58 UTC−4
Can anybody send me a very basic implementation of ALE like shrinking of a circle or square with time. I am trying to implement ALE without any physics (for simplification). But I am not seeing the desired result. I just get back the initial geometry. I don't know what mistake I am making.
Sanket
Can anybody send me a very basic implementation of ALE like shrinking of a circle or square with time. I am trying to implement ALE without any physics (for simplification). But I am not seeing the desired result. I just get back the initial geometry. I don't know what mistake I am making. Thanks Sanket
Posted: 1 decade ago 9 mai 2012, 09:01 UTC−4
Hello Giulio,
I tried to run your .mph file but i don't see any convergence problems ! ! ! Are you worried because the total displacement computed of 0.01 [µm] is much bigger than the prescribed one of 4.10^-7 x 1[nm]???
According to what Ivar told you, what kind of changes did you make to make it work better? could you upload the final file please?
Hello Giulio, I tried to run your .mph file but i don't see any convergence problems ! ! ! Are you worried because the total displacement computed of 0.01 [µm] is much bigger than the prescribed one of 4.10^-7 x 1[nm]??? According to what Ivar told you, what kind of changes did you make to make it work better? could you upload the final file please? Best regards,
