Nirmal Paudel
Tribhuvan University/Electrical Engineering
7 years ago
2 oct. 2017, 09:32 UTC−4
Hi Michael,
If you use the "Rotating Machinery, Magnetic (rmm)" physics interface in AC/DC Module, it will be very easy and automatic to apply the radial or axial magnetization as done in the following examples. I would suggest you to take a look and apply the same method in your modeling needs.
1. https://www.comsol.com/model/generator-in-2d-2122
2. https://www.comsol.com/model/electrodynamic-wheel-magnetic-levitation-in-2d-44871
Best Regards,
Nirmal Paudel
Hi Michael,
Best Regards,
Nirmal Paudel
7 years ago
2 oct. 2017, 10:01 UTC−4
Hi Nirmal
Thanks for your fast response.
Sorry, I may have explained my situation a little bit too simplified... I have a flexible catheter with a magnet on it's tip. I'm trying to simulate the behaviour/deformations of this catheter when a magnetic field is applyed.
Based on my knowlege the tip of the catheter should be displaced and rotated in order to align with the magnetic field...
So far I used a combination on magnetic fields, no currents and solid mechanics... But, as said, i'm not able to model an axial magnetisation. As it is not a simple ratation I can't use a cylindrical coordinate system with fixed origin. I was not able to find how to fix a coordinate axis to a body axis.
Best
Michael
Hi Nirmal
Best
Michael
