Error; how to interpret.
Hi there,
I've set up a multibody-model with contact, though when I open the model file, I get the following message:
Invalid property error: - Property: segcomp 'Selection' is an array of strings Variable component strings
My model runs fine as far as I can see, but I'm not comfortable with getting errors I don't know what means. Does anyone know what the error message refers to, or - in general - where / how to figure it out?
Thanks in advance!
Besr regards David
2 Replies Last Post 25 sept. 2017, 04:45 UTC−4
Posted: 7 years ago 23 sept. 2017, 01:56 UTC−4
Those type of errors are typically what I send to "support", if you have a maintenance contract, something I can only recommend for a FEM programme as complex as COMSOL. We, in our company, are getting excellent help via "support" for such often low level error messages. As the COMSOL developpers are the only really knowing how to interpreete these low level error messages. It looks like a Composed Selection issue. So I would start by going carefully through all the model nodes and double check the selections in particular (but I might be wrong), specially looking for yellow (units warning) or red entries, allthough I suspect this error will not flag itself with a color code.
Good luck Ivar
Have fun COMSOLing,
Sincerely,
Hi Those type of errors are typically what I send to "support", if you have a maintenance contract, something I can only recommend for a FEM programme as complex as COMSOL. We, in our company, are getting excellent help via "support" for such often low level error messages. As the COMSOL developpers are the only really knowing how to interpreete these low level error messages. It looks like a Composed Selection issue. So I would start by going carefully through all the model nodes and double check the selections in particular (but I might be wrong), specially looking for yellow (units warning) or red entries, allthough I suspect this error will not flag itself with a color code. Good luck Ivar
Posted: 7 years ago 25 sept. 2017, 04:45 UTC−4
Hi Ivar,
Thank you for your reply. I cannot find any red flags at the model nodes, so I've submitted the question to 'support'.
\David
Hi Ivar, Thank you for your reply. I cannot find any red flags at the model nodes, so I've submitted the question to 'support'. \David
