Weak form vs. Coefficient form PDE
I have implemented a coupled problem of simple two phase flow in porous media in coefficient form PDE and also in weak form PDE. However the results are not identical. I can not figure out what the problem is and how to correct it. The dependent variables are ‘p’ and ‘s’. The coupled equation is
C1 Delta(p) =0
C2 ds/dt+ C3 Delta(p)+ C3 Delta(s)=0
where
Delta=Laplacian=grad.grad
And in weak form
(C1)*(test(px)*px+test(py)*py)
-C2*test(s)*st+(C3)*(test(px)*px+test(py)*py)+(C4)*(test(sx)*sx+test(sy)*sy)
Is there any problem with this weak from?
I have uploaded my model. Can any body please check my model and find the problem.
Thank you in advance.
5 Replies Last Post 10 mars 2011, 07:39 UTC−5
Posted: 1 decade ago 9 mars 2011, 12:08 UTC−5
I found out that the problem is with Flux/source boundary condition in weak form. It doesn't contribute in the model. But I still don't know why.
Posted: 1 decade ago 10 mars 2011, 05:28 UTC−5
I think that you weak form is wrong.
Your firs equation in my Comsol becomes
C1*(-px-py)*test(p)
Ciao Anto
I think that you weak form is wrong. Your firs equation in my Comsol becomes C1*(-px-py)*test(p) Ciao Anto
Posted: 1 decade ago 10 mars 2011, 06:05 UTC−5
Thank you for reply.
Sorry I made a mistake in writing my system of equation. Actually I should have written it like:
C1 Delta (p) =0
C2 ds/dt+ C3 Delta(p)+ C3 Delta(p)=0
Here
Delta=Laplacian = grad. garad
And in weak form
I still have problem with the boundary condition in the weak form. It doesn’t work properly.
I have corrected my first post.
Thank you for reply. Sorry I made a mistake in writing my system of equation. Actually I should have written it like: C1 Delta (p) =0 C2 ds/dt+ C3 Delta(p)+ C3 Delta(p)=0 Here Delta=Laplacian = grad. garad And in weak form (C1)*(test(px)*px+test(py)*py) -C2*test(s)*st+(C3)*(test(px)*px+test(py)*py)+(C4)*(test(sx)*sx+test(sy)*sy) I still have problem with the boundary condition in the weak form. It doesn’t work properly. I have corrected my first post.
Posted: 1 decade ago 10 mars 2011, 06:21 UTC−5
I suppose that your laplacian is
delta=div.grad
and your equations read
(i) C1 delta(p)=0
(ii) C2 ds/dt + C3 delta(p)+C4 delta(s)=0
Now if delta(p) is zero by (i) the second will be simply
(ii) C2 ds/dt + C4 delta(s)=0
and the second equation is no more coupled to the first.
In any case the weak form is
(i) C1*(-Px*test(Px)-Py*test(Py))
(ii) (-C3*Px-C4*Sx)*test(Sx)+(-C3*Py-C4*Sy)*test(Sy) + C2*St*test(S)
Rob
I suppose that your laplacian is delta=div.grad and your equations read (i) C1 delta(p)=0 (ii) C2 ds/dt + C3 delta(p)+C4 delta(s)=0 Now if delta(p) is zero by (i) the second will be simply (ii) C2 ds/dt + C4 delta(s)=0 and the second equation is no more coupled to the first. In any case the weak form is (i) C1*(-Px*test(Px)-Py*test(Py)) (ii) (-C3*Px-C4*Sx)*test(Sx)+(-C3*Py-C4*Sy)*test(Sy) + C2*St*test(S) Rob
Posted: 1 decade ago 10 mars 2011, 07:39 UTC−5
Dear Rob
I really appreciate your help. I corrected my weak form and it works.
Mojtaba
Dear Rob I really appreciate your help. I corrected my weak form and it works. Mojtaba
