Error in evaluating variable Jacobian. - Variable: mat.nu
Hello everyone,
I 'm using comsol V4.1a.
I am trying to simulate electromagnetic force problem in solid mechanics model.
But I am having the following prob.
Error:
Failed to evaluate variable Jacobian.
- Variable: mat.nu
- Geometry: 1
- Domain: 2
I removed Air from solid Geometry but still have same error.
I cant find out the error.Please help me.
M.Ali
7 Replies Last Post 1 juil. 2011, 01:08 UTC−4
Posted: 1 decade ago 8 mars 2011, 01:35 UTC−5
"nu" is the Poisson coefficient, are you sure you have rechecked your material settings and nothing is missing ?
Hi "nu" is the Poisson coefficient, are you sure you have rechecked your material settings and nothing is missing ? -- Good luck Ivar
Posted: 1 decade ago 8 mars 2011, 03:26 UTC−5
I fixed that error but still have
Error:
- Variable: ec.Jz
- Geometry: 1
- Domain: 2
what is this error for?
Thanks, I fixed that error but still have Error: Failed to evaluate variable Jacobian. - Variable: ec.Jz - Geometry: 1 - Domain: 2 what is this error for?
Posted: 1 decade ago 8 mars 2011, 04:35 UTC−5
I fixed this problem.
thnx
Hi, I fixed this problem. thnx
Posted: 1 decade ago 1 avr. 2011, 02:30 UTC−4
i have same problem like you?
could you explain me how you solved it?
i have geometry of floating buoy on fluid.at the computing it shows jacobian error and sol1/t1 failed to compute....
i have same problem like you? could you explain me how you solved it? i have geometry of floating buoy on fluid.at the computing it shows jacobian error and sol1/t1 failed to compute....
Posted: 1 decade ago 1 avr. 2011, 13:10 UTC−4
It's comsol bug that has to get fixed. anyway, you have to change the Jacobian name to capital form. like ec.JZ, instead of ec.Jz.
Ali
It's comsol bug that has to get fixed. anyway, you have to change the Jacobian name to capital form. like ec.JZ, instead of ec.Jz. -- Best regards, Ali
Posted: 1 decade ago 2 avr. 2011, 10:48 UTC−4
then it's probably not a "bug" as z and Z are not refering to the same frames, it's related with the Eulerian or Lagrangien reference frames, take a look at
en.wikipedia.org/wiki/Lagrangian_reference_frame
Hi then it's probably not a "bug" as z and Z are not refering to the same frames, it's related with the Eulerian or Lagrangien reference frames, take a look at http://en.wikipedia.org/wiki/Lagrangian_reference_frame -- Good luck Ivar
Posted: 1 decade ago 1 juil. 2011, 01:08 UTC−4
I am getting a similar error.
Failed to evaluate variable jacobian
- Variable: u
- Geometry: 1
- Dimension: 2
- Domain group: {1,7}
I am doing conjugate heat transfer in 2d. Basically trying to connect weakly compressible NS and General HT. In subdomain settings of HT when i put u and v after enabling convective ht, i get this error. How can i get rid of it?
I am getting a similar error. Failed to evaluate variable jacobian - Variable: u - Geometry: 1 - Dimension: 2 - Domain group: {1,7} I am doing conjugate heat transfer in 2d. Basically trying to connect weakly compressible NS and General HT. In subdomain settings of HT when i put u and v after enabling convective ht, i get this error. How can i get rid of it?
