laminar flow
Sir i have designed one sensor ...With application of some force it is giving strain...Now i want to put the sensor in the boundary where laminar flow is applied.... Now i want to calculate the strain when the flow is applied....FOr this u have told me to use FSI module...I have only license for AC/DC module ana MEMS module in my college...Iam solving with the help of these two models for the strain but iam not getting the output...NOw wat i can do????
1 Reply Last Post 7 mars 2011, 01:14 UTC−5
Posted: 1 decade ago 7 mars 2011, 01:14 UTC−5
I believe the FSI physics is part of the MEMS, check under FluidFlow (with V4 the MEMS physics are no longer under a "MEMS" title, but distributed under the different physics, this is valid for all modules).
You should get updated to the latest version, you will be less frustrated
Hi I believe the FSI physics is part of the MEMS, check under FluidFlow (with V4 the MEMS physics are no longer under a "MEMS" title, but distributed under the different physics, this is valid for all modules). You should get updated to the latest version, you will be less frustrated -- Good luck Ivar
