How to continue the calculation of unfinished cases
Posted 26 mai 2017, 05:59 UTC−4 7 Replies
if it is a time dependent study, you can continue the study. You have to interrupt the study manually by using the STOP buttons. If it completes normally, the continue option is not available anymore. @Comsol: This should be changed ...
Other models may be continued by setting up a second study that takes the solution from the interrupted study as initial condition. This works for time dependent too. You have to set the start time of the second study equal to the stop time of the first.
If your model comprises a parametric sweep things may get complicated, no solution here in this case so far.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Sorry, we don't do any CFD work. But maybe others can help.
Edgar J. Kaiser
www.emphys.com
I know. I mean that do you have any module to do coalescence but not that slow as level set.
Kind Regards,
Li Bin
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Dear Edgar,
I am using level set method. It seems that even though I set up a second study that takes the solution from the interrupted study as initial condition, the second study calculate from the original initial condition, and I got the same results as the first study. So, does your method fit in level set method? Thanks.
Kind Regards,
Bin Li
Edgar J. Kaiser
www.emphys.com
Cheers
Bin Li
Suggested Content
- FORUM Continue transient study step from last time step
- FORUM How to continue the study after stopped using livelink for matlab?
- KNOWLEDGE BASE Setup and Meshing of Infinite Elements, Perfectly Matched Layers, and Absorbing Layers
- BLOG Designing Inductors with a Simulation App at Bombardier Transportation
- FORUM Continue solution in multistep study
