Dave Greve
Certified Consultant
8 years ago
18 févr. 2017, 11:23 UTC−5
In newer versions of Comsol silicon dioxide mechanical properties are built-in (the material choice is silica glass).
If you are talking about amorphous silicon dioxide (same as silica glass) the material properties are isotropic. So there are only two parameters (for example, Young's modulus and Poisson's ratio). You do not need to enter elements of the elasticity matrix.
Now if you are talking about crystalline silicon dioxide- that is, quartz: then things are much more complicated.
DW Greve
DWGreve Consulting
DW Greve
DWGreve Consulting
8 years ago
18 févr. 2017, 11:35 UTC−5
I am designing sensor model with SOI Technology in the COMSOL Multiphysics, I need to enter the Elasticity matrix for silicon dioxide.
Dave Greve
8 years ago
18 févr. 2017, 15:16 UTC−5
No, I do not think you need to enter the elasticity matrix.
I can't say for sure because I do not have a copy of 4.3 to look at. But in most versions of Comsol, if you define a material as linear isotropic the only parameters you need are the Young's modulus and the Poisson ratio. These can be looked up on the web but I suspect the parameters are built in to your program.
The oxide in an SOI process is amorphous silicon dioxide or silica glass.
