Job option in Batch command
Posted 12 janv. 2011, 09:47 UTC−5 Studies & Solvers 5 Replies
Hi all,
I add trouble when using the batch command recently. I prepared one file with a parametric study (different amplitudes are used in a time dependent problem).
I didn't try yet the -pname and -plist option, but instead I tried to prepare my file with a parametric study ( I entered all my values), I also set the cluster settings so I can run them in parralel.
But then, when I tried to run it via batch, the option was not recognized... the job name was not recognized. I thus wonder how to call a dedicate study from one saved file. Let say that I have one of my study which is called 'parametrik' ... I want to use batch to compute this dedicate job. Is it possible? How should I write the command?
Here is the code I used :
comsol batch -inputfile batch_file.mph -outputfile batch_file.OUT.mph -job parametrik
Here is the log message :
Unknown_batch_feature
Exception:
com.comsol.util.exceptions.FlException: Unknown batch feature
- Tag: parametrik
Exception:
- Tag: parametrik
5 Replies Last Post 3 déc. 2013, 22:10 UTC−5
