Missing expressions for some variables in Particle Tracing for Fluid Flow Study
Hello everyone,
Currently, I'm trying to model an Acoustic Levitation phenomenon by using COMSOL 5.0. When approaching the Acoustophoretic Force physics in Particle Tracing for Fluid Flow Study, the equation assuming tab have several variables definition including Force Ft, Urad, f1, f2 values. However, when I open the equation view of this physics, there are only two expressions including Acoustophoretic Force whose expression is 0 and Total force. I don't know whether the remaining variables are gone. I think they should be defined in the Equation View.
Could you please help me?
Cheers,
Huy
2 Replies Last Post 1 mars 2017, 21:05 UTC−5
Hello Huy Pham
Posted: 8 years ago 27 févr. 2017, 17:05 UTC−5
I encounter the same problem. Have you solved it ? Could you please tell me where is the missing variables? Thank you so much.
Hi, I encounter the same problem. Have you solved it ? Could you please tell me where is the missing variables? Thank you so much.
Posted: 8 years ago 1 mars 2017, 21:05 UTC−5
Dear Mate,
You just need to run the Particle Tracing Module with Time Dependent Solver. You should choose a coarse mesh so that the solver releases the result fast. Then you can look at the "Equation View" of Acoustophoretic Force and all the equations appear.
Cheers,
Quoc
Dear Mate, You just need to run the Particle Tracing Module with Time Dependent Solver. You should choose a coarse mesh so that the solver releases the result fast. Then you can look at the "Equation View" of Acoustophoretic Force and all the equations appear. Cheers, Quoc
