9 years ago
19 sept. 2016, 17:07 UTC+2
I have attached a very simple (axisymmetric, stationary) coil and permanent magnet model as a starting point. Note that it is a version 5.2a file, so not sure if you will be able to open it, but that's the only version I have.
Basically, to calculate the force, you will need to define a Force Calculation node in the "mf" interface., and select the domain for which you want to calculate the force. Give the force a name so that you can use it as a variable within your model.
Things get a little more complex if you have non-linear steels in your model, and/or time varying fields or moving meshes.
Hopefully the attached gives you a starting point.
9 years ago
20 sept. 2016, 07:00 UTC+2
I couldn't open the file. I was able to find the force between two permanent magnets which would be similar to a stationary field and permanent magnet that you mentioned here. But I need to find the force between the permanent magnet and time varying magnetic field. If you could give the steps for that it would be very useful for me. Anyways Thanks for your reply.
