Need help in understanding how to develop Oscillatory flows inside a pipe
Posted 22 août 2016, 19:27 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 5.2 0 Replies
I am solving a FSI problem where the oscillatory fluid flow inside a pipe is deforming the solid. I am using COMSOL for the numerical simulation of the system. I have a rectangular pipe (2D) and at the inlet of the pipe defined a pressure condition (forcing condition) to create oscillation in the flow.
my inlet condition is:
P(inlet)= P_mean + P_amplitude * cos (wt) -- (time dependent analysis)
Outlet condition is also kept as pressure condition having same equation as inlet but with sin term to create phase difference in the inlet and outlet pressure at each time step.
P(outlet)= P_mean + P_amplitude * sin (wt) -- (time dependent analysis)
the outlet condition was kept this way to continuously maintain pressure difference which will govern the fluid flow in the forward direction and then reverse its flow to create oscillations.
It is very much critical for me to define accurate pressure conditions as the solid deformation is dependent upon the fluid flow. Can anyone please tell me if is the right way to define pressure equation to create oscillatory flows? If not, please share your insights on the same.
Thanks.
Hello Sajiree Vaidya
