Solution not computed error message
Please, what can cause this error "Solution 1 is not computed"?.
2 Replies Last Post 19 juil. 2016, 03:18 UTC−4
Posted: 8 years ago 19 juil. 2016, 03:09 UTC−4
The full error message is
Solution 1 is not computed.
- Feature: Dependent Variables 1 (sol1/v1)
The full error message is Solution 1 is not computed. - Feature: Dependent Variables 1 (sol1/v1)
Posted: 8 years ago 19 juil. 2016, 03:18 UTC−4
I am running a turbulent flow through a long pipe; having several inlets. The domain has both outer and inner wall boundaries, with no-slip conditions; It is a time dependent problem.
Any suggestion will be appreciated.
I am running a turbulent flow through a long pipe; having several inlets. The domain has both outer and inner wall boundaries, with no-slip conditions; It is a time dependent problem. Any suggestion will be appreciated.
