How to selectively remove materials in a Heat Transfer model using filter in result node or geometry update using stop conditions?
Posted 27 juin 2016, 00:47 UTC−4 Heat Transfer & Phase Change, Geometry, Results & Visualization Version 5.2 1 Reply
Hi All,
I am using a heat transfer model in COMSOL 5.2 version. The material consists of two domains. When the temperature is higher than the vaporization temperatures of the two materials, the materials should be selectively removed. I am trying to get this in the result node in 3D plot by using filter. My question is how can i use two vaporization temperature values in the logical expression to plot the selective material removal from both the domains? or is this also possible in the geometry update using stop conditions? Could you please help me out here?
Thanks and regards,
Uma Shankar
Thanks and regards,
Uma Shankar
1 Reply Last Post 27 juin 2016, 10:55 UTC−4
