Does Comsol4 have the function of Time-integral?
We can do Integration at several places in Comsol4, but it seems that all are space-integral, such as a domain, a boundary ---
If I want to do an Integration at a range of time, How should I do?
8 Replies Last Post 17 janv. 2012, 10:37 UTC−5
Posted: 1 decade ago 16 oct. 2010, 11:19 UTC−4
this has been discussed a few times, try a search on the Forum, but I cannot remember the "good" solution, as I do not believe there is a "time integration" operator as for the space integration.
In som cases you can change the time variable to a space variable, if you can adapt the equations
Hi this has been discussed a few times, try a search on the Forum, but I cannot remember the "good" solution, as I do not believe there is a "time integration" operator as for the space integration. In som cases you can change the time variable to a space variable, if you can adapt the equations -- Good luck Ivar
Posted: 1 decade ago 18 oct. 2010, 12:56 UTC−4
see www.comsol.com/support/knowledgebase/913/
see http://www.comsol.com/support/knowledgebase/913/
Posted: 1 decade ago 18 oct. 2010, 15:46 UTC−4
Thanks Ozgur, I forgot to search on the KB, I was sure it was somewhere ;)
Hi Thanks Ozgur, I forgot to search on the KB, I was sure it was somewhere ;) -- Good luck Ivar
Posted: 1 decade ago 19 oct. 2010, 14:29 UTC−4
Thanks, Ozgur
[QUOTE] see http://www.comsol.com/support/knowledgebase/913/ [/QUOTE] Thanks, Ozgur
Posted: 1 decade ago 19 oct. 2011, 02:03 UTC−4
the suggestion was useful for me too!! thanks
Posted: 1 decade ago 19 oct. 2011, 04:56 UTC−4
Right on, Ozgur, and in release 4.2a we have some nice news on this topic:
New additional time-dependent solutions operators that you can use for results evaluation, for example:
- timeint() for time integration
- timeavg() for time averages
4.2a will start shipping end of this week.
Niklas
[QUOTE] see http://www.comsol.com/support/knowledgebase/913/ [/QUOTE] Right on, Ozgur, and in release 4.2a we have some nice news on this topic: New additional time-dependent solutions operators that you can use for results evaluation, for example: - timeint() for time integration - timeavg() for time averages 4.2a will start shipping end of this week. Niklas
Posted: 1 decade ago 17 janv. 2012, 09:58 UTC−5
Hello Niklas,
I was wondering where may I find the time integral function timeint()? It would be great if you may drop quick tips to use this function
However, sugestions from Ivar and knowledge base 913 was helpful.
-Thanks
Kumar
Hello Niklas, I was wondering where may I find the time integral function timeint()? It would be great if you may drop quick tips to use this function However, sugestions from Ivar and knowledge base 913 was helpful. -Thanks Kumar
Posted: 1 decade ago 17 janv. 2012, 10:37 UTC−5
The special operator "timeint()" is in v4.2a (1.66 is my current one) try a help search "timeint" or "special operators"
It's limited to post processing though. For the solver process you must go via the ODE as described in the KB
Hi The special operator "timeint()" is in v4.2a (1.66 is my current one) try a help search "timeint" or "special operators" It's limited to post processing though. For the solver process you must go via the ODE as described in the KB -- Good luck Ivar
