How to change the resin flow direction of a model?
Posted 8 févr. 2016, 10:23 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 5.1, Version 5.2 1 Reply
I am trying to use the model of Permeability Estimation Application ID: 33331 , As we know, in this example, the direction of the resin flow is from bottom up, and if I want to change the direciton of the resin flow such as from top to bottom or from right to left how can I set the boudary or change the parameter? Thank you very much!
1 Reply Last Post 9 févr. 2016, 04:23 UTC−5
