Export parametric 2D surface plot to multiple images
Posted 12 janv. 2016, 03:12 UTC−5 Version 5.1 4 Replies
I did a parametric sweep simulation with a combined material sweep. Now I defined a surface isoplot which I want to export to an image file. And I want to do that for each combination of parameter and material, which results to a number of images. To do this manually needs quite some time, so I wondered if there is a way to automatically export each combination to a separate image file based on the defined export node?
I'd like to define a description with the parameter value and this value should be part of the file name.
Any help is appreciated.
Andre
Andre
4 Replies Last Post 4 févr. 2016, 03:57 UTC−5
